Single 'knock' from rear suspension when pulling off or breaking.
Old 12-05-2002, 12:48 PM
  #21
Billman250's Avatar
Received 1,401 Likes on 839 Posts
i keep seeing this problem over and over. ITS THE REAR AXLE NUTS. the splines are shifting back and forth in the hub. get 2 new nuts and torque them to 225 ft lbs. problem solved.
Old 12-26-2002, 12:19 PM
  #22
Pixsurguy's Avatar
Originally posted by cerberus264
Thats the brakes though.
rlloyd's problem is related to the drivechain.
I have exactly the same problem (i think). When you've engaged 1st or reverse gear - let off the clutch, as the drive is taken up and the car starts moving there is a clunk from the rear of the car.
Same here. Never happened until I got the car back from the dealer when they put in a new ring & pinion. Also, was able to get rubber in first four gears. Can't get it in ANY gear now. This has been going on for about a month.
Old 12-28-2002, 03:26 AM
  #23
cerberus264's Avatar
Mine's now been fixed under warranty by Honda:; Re-grease the drive cups and fitted and re-torqued new axle nuts.
...sorted!
Old 12-15-2007, 02:03 AM
  #24
jonnybmb's Avatar
ive also got this problem, honda re greased cv joints= no difference, i have tightened hub nuts= no difference can anyone help?
Old 12-15-2007, 12:05 PM
  #25
philipxhuff's Avatar
Axle Pops or Creaks:
ajs2000
09-25-2008 03:10 PM
zagamuffin
09-12-2008 10:59 PM
JS2k.com
07-17-2008 06:48 PM
russellhq
02-26-2007 01:55 PM
KaMxiKaZe
06-11-2005 04:09 PM
Quick Reply: Single 'knock' from rear suspension when pulling off or breaking.
