Single Cross-threaded Spark Plug
I got a pretty good scare last night after I did a compression test on MY02 at a buddies house. I put all the plugs and coils back in, but when I started up and pulled out of my friends drive way, the S was gurgling and sputtering and threatening to die when the rpm's were below 3,500. Also the check engine light came on and was flashing which was definitely not a good thing. So I came back later and took the coils out, made sure all the plugs were tightened and they were so I put the coils back and started up again but nothing was fixed. My friend scanned for the CEL code and it came back with the same code I would get if I had blown my engine. So I had my friend go back through and take everything out and put it all back in and magically it ran fine so I'm guessing it was the spark plugs. Anyways I was just wondering, is it normal for a cross threaded spark plug to really have that much of an effect on engine performance?
As to your questions. Yes, if the plug can't ignite the air/fuel mixture, then you are down to 3 cylinders and dumping fuel into the catalytic converter.
I see. Yeah I didn't see the actual code, my friend just said that that's the code you'd get if you had a blown engine. Yeah I took it out last night and got into vtec and cruised around and all seemed well so I think everything is resolved and the threads are fine. Thanks for the input!
Puppy
09-08-2008 12:50 PM
volcomrider6
02-17-2006 04:37 PM
