single clunk from right rear tire
i have read many posts about this single clunk from the rear.
car is a 01 and i mainly notice it when i am taking off. or if i am moving and shift from nuetral to second i hear the"clunk" it is a single clunk.
basically it is either:
1 brake pads popping?
2 axle nut need to be retorqued?
3 or??
3 or??
Originally Posted by socalhonda,Nov 16 2007, 04:12 AM
I mainly notice it when i am taking off, or if i am moving and shift from nuetral to second I hear the"clunk" it is a single clunk.
Originally Posted by RACER,Nov 16 2007, 08:37 AM
Can you give a better description?
then i was driving only going slow and i put it in neutral then to second. and i heard the "clunk" again!
but this clunk doesnt happen all the time. only sometimes.
i mainly notice from rolling very slow and i put it into 1st or rolling and i put it into second. i hear the "clunk"
i also noticd it coming onto a turn on the freeway (slow speeds) right turn i heard the "clunk" it is a single clunk.
i think i even heard it when i hit a bump.
thanks for the help!
The rear on my car make s a one sided (driver's) clunk too- I only hear it when going straight and when Im in neutral rolling to a stop or starting in 1st gear. I also hear what sounds like worn out mattress springs squeaking. This occurs when I get in and out of the car, go over bumps, or push down on the trunk. I think this is unrelated, possibly a worn out ball joint tho.
Originally Posted by attack666,Nov 16 2007, 01:42 PM
I get the same clunk when in 1st or reverse..Will ignoring it cause a problem ?
