Silicon grease for top
Received 1,744 Likes
As far as the rubber seals go for the top, I have read quite a bit in discussions and on line about Shin Etsu grease available from Honda. (Its repackaged by Honda-not made by them) Honda recommends its application to rubber seals to maintain their function and appearance. The problem? My dealer wants $70 for a substantial size tube. Ouch! I can see other sizes are available online and from the manufacturer at lower prices.
Now I have found and use 3M Silicone Paste and also Gunk brand 'Plumbers Grease' for household applications: my pool equipment, water softener, plumbing, electrical and other uses. (Use it to treat contacts on bulbs to prevent corrosion. Also used for batteries.) Great stuff. Comes in a 8oz bottle or small white plastic tub. Why not this instead of Shin Etsu? Time for some research.
Although the precise chemical breakdown is not listed on either containers, you can find out alot from the websites and uses for the products. I will spare you on endless details but let me throw in this definition of 'silicone grease':
Silicone grease is a waterproof grease made by combining a silicone oil with a thickener. Most commonly, the silicone oil is polydimethylsiloxane and the thickener is amorphous fumed silica. Using this formulation, silicone grease is a translucent white viscous paste, with exact properties dependent on the type and proportion of the components.
Silicone grease is commonly used for lubricating and preserving rubber parts, such as O-rings. Additionally, silicone grease does not swell or soften the rubber, which can be a problem with hydrocarbon based greases. It functions well as a corrosion-inhibitor and lubricant for purposes that require a thicker lubricant, such as the operating mechanism of the S top. (Also firearms etc)
The most common use of it is an elastic heat transfer coupling material between semiconductor circuit elements and attached cooling metal parts. This way thermal resistance of touching surfaces is typically lowered by 50 percent. The high thermal stability is the key property that allows these greases to operate on hot, cold and wet surfaces of peltier elements.
Silicone grease is also used widely by the plumbing industry in faucets and seals, as well as dental equipment. Electrical utilities use silicone grease to lube separable elbows on lines which must endure high temperatures. Silicone greases generally have a temperature range of -40 to 400 °C.
Silicone grease is widely used as a temporary sealant and a lubricant for interconnecting ground glass joints, as is typically used in the chemical laboratory. Although silicones are normally assumed to be chemically inert, several historically significant compounds have been prepared by unintended reactions. For example, the first salt of the crown ether (OSi(CH 3 ) 2 ) n (n = 6, 7) were prepared by reactions resulting from contacting organolithium and organopotassium compounds with silicone greases.
Silicone-based lubricants are often used by consumers in applications where other common consumer lubricants, such as Vaseline, would damage certain products, such as latex rubber condoms and gaskets on drysuits.
The salient points are the presence of the silicone ingredient and NOT petroleum additives which attack rubber. (Thats why Vaseline and condoms do not go together well)
The 3M and Gunk Dielectric grease matches those qualities of Shin Etsu: Has temp range of -40 to 400 degrees F, Does not melt. Waterproof protective coating that prevents rust and corrosion. Rubber and synthetic, plastic, metal and ceramic materials. Certified ANSI/NSF 61. Made in USA.
Contains Polydimethylsiloxane/63148629, Dimethyl Siloxane, Hydroxyterminated/70131678, Silica, Amorphous Fumed/7631869.
Pretty much the same industrial ingredients for this class of product including Shin Etsu.
Bottom line: it seems to me the 3M grease is really pretty much the same quality and composition at a much cheaper price.
Auto parts stores sell this 3M Silicone Paste. It is listed as a Dielectric grease that happens to have automotive uses that, in our case here, would include rubber seals that Honda's Shin Etsu is used for but you can get an 8oz bottle for a little over $10.
A little goes a long way.
