Sign of a Slipping Clutch?
im gonna make this short..
1. redline first
2. 2nd gear holds around 6.5k.. then after a couple seconds.. grabs n pulls harder up to 8ish..
never noticed this b4.. but it was cold outside and the car felt damn strong.. just felt like a delay or something.. does this sound like the clutch is not grabbing 100% when shifting to 2nd ?
1. redline first
Seach for the "clutch delay valve" mod.
Because Honda was having problems with people launching and f'ing up rear diffs, they put the clutch delay valve on the clutch cylinder. When you pop the clutch, it doesnt let the clutch fully grab, and instead it will burn the clutch a little bit to save the differential from taking all the extra wear and tear.
You can replace your cylinder with one from 00-03, there are many many threads, check in one of the stickies for a link to DIY's and how-to's
edit: here is the DIY index..
https://www.s2ki.com/forums/index.php?showtopic=108435
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Originally Posted by Ztopgun28,Jan 18 2007, 09:13 AM
So is it safe to leave this valve alone if I dont have a reinforced diff?
![wink.gif](https://www.s2ki.com/forums/images/smilies/wink.gif)
Yes its safe, I removed mine and I haven't had any problems. I dont launch the car/ drag race, but I do shift quickly when in the canyons or at the track. The car is much better now that the valve is gone.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![confused.gif](https://www.s2ki.com/forums/images/smilies/confused.gif)
