Is this a sign of a bad throwout bearing?
Here's a video: https://photos.app.goo.gl/wEwGRTGHjd8nryzHA
It seems to happen with or without the clutch being pressed. I had it in first gear at the time of the video.
What do you guys think?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
I didn't notice it until I was parked and stationary.
I just started noticing it last night. I had the car in neutral and was about to turn off the car when I started hearing it. When I took out my phone to try to record the sound, I tried pressing clutch in/out, and it seems to act the same. It's not a constant noise - it seems to go away and start again every few seconds. The video was taken after a 30 min drive home.
A trans rollover noise should be constant there just sitting at idle in neutral and should go away pressing the clutch in for a few seconds.
Honestly it sounds like something grounding something out and rattling (did you drop something behind the engine? An oil cap is common to get stuck between the bellehousing and firewall.....can you feel any vibration through the firewall/pedals?) combined with throwout bearing noise.
How many miles are on this vehicle? And is this a stock clutch?
One of the noises I feel is completely normal, my vehicle makes the same sound when releasing the clutch at idle. The other I'm not completely sure about.
Thanks for the explanations. Currently at 67k miles, its an 06. As far as I can tell, this is the stock clutch - I don't believe it was ever replaced before.
I haven't worked on the engine recently, so pretty sure nothing fell through. I'll take a glance under the hood for any caps missing later today. Nothing feels obviously weird in terms of clutch pedal feel.
I have had it slip a little bit on full throttle shifts at the track, so I was already planning on replacing the clutch when it showed signs of slipping during street driving. Perhaps the other components wore out first. I'm just hoping its replaceable clutch components rather than the transmission itself, hah.
The previous owner might have dropped something too. But regardless when you drop the trans you'll know if there was something up there!
I'd go ahead and replace the trans fluid while you're at it.
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
Oil cap as above was a headache for me..
<Lost oil cap>
<Lost oil cap>
HawkeyeGeoff (10-25-2019)
Your clutch slip you feel at a track would be normal for a 06 driven hard and shifting fast due to clutch delay valve, it was put in by Honda to save on differential warranty claims, many remove them. It would be unusual to need a clutch at your mileage, but you don’t know how the last owners drove.
A throwout bearing noise will be constant and present only when when the clutch pedal is at it's out position aka not touching the pressure plate fingers. It sounds kind of like a throwout bearing noise in the video with a combination of something else.
The throw out bearing usually is in constant contact with the PP and therefore spinning. I've seen it both ways but it seems to be more common to have an always contacting one. This is why they can make noise.
