sigh spindle nut probs i think
There could be some concern forl ong term result. I mean the nuits wont fall off since they are staked but doing some research and talking to xviper the wheel bearing could get worn out after awhile perhaps. But again I've had this for awhile and just now going to do something about it lol...the littlest things get to me!!
Good ideaabout retorqueing both wheels!
Also hoth you said u bought new nuts? Did you break the old ones when you took them off? All you need to do this job is basically a torque wrench to go 225 and grease. I don't have the wrench hence the honda mechanic plus he probably would be able to take the screws off without breakage.
I mean when I first got my s2k a awhile back, every time I hit revers that small click sound would be there and I was like fuk i hope its not the diff. Then I changed the diff fluid recently and nothing bad came out and mechanic said car was perfect. So I still go that noise so 99% its the nuts so again its been here for awhile and car drivers perfect
wheel bearing replaced? did u go for along time withouth retorquing it to 220? So your car did make a notciable loud noise when it was accelrating past 50 (one symtom of wheel bearing failure)
It was probably a month or so before attempting the retorque. Apparently that was too long or it was on its way out anyways. The noise actually sounded more like a rub of the brake shield, one noise per wheel revolution. Was quite noticeable at low speeds (>10mph)...
I just had this one, the Axle Pops or Creaks, done by an independent. (At 50,000 miles I'm way out of warranty. Cost $8 for two new spindle nuts and $44 labor.) It isn't a TSB, but something less official called a Technical Service Note, #011201. VFROOOM posted an image of it in the updated TSB list thread.
I watched the tech do the work. The noise is due to the spindle nut rubbing against the hub. What fixes it is the grease they apply between the nut and the hub. The extra torque isn't strictly necessary, just a little more friction to keep it from shifting around as much. Except that the noise is annoying, you could probably go 100,000 miles without it becoming a mechanical issue.
wow $44 for labor? At most it would take 20-30min for a mechanic to to unpry the center piece of the wheel, take of the nut re grease then troque it and your done? Am i missing something?
again I'm going in tommorow with no new nuts as Xiper has suggested you can re use the old nuts.
did they damage your old nuts ron hence you used new ones?
The nut is spiked in place by using a hammer and screwdriver to bend in one side after torquing it down. It is already damaged before you take it off. If you are lucky, after you retorque to 220 ft-lbs a different side may be at the spike point so spiking a second time will work, but the nut is clearly not intended to be used more than once.
$44 sounds about right.
haha ok I take back the $44 I payed $33 but the guys I go to are awesome veyr fast and clean job. I even bought new bolts just cause they were so cheap! 2 bucks for each one I think remember to mention rear spindle nuts not front ones.
Well guess what..........the CLICKING noise is gone!!!!! totally gone!!!!
So if you need this done fast and clean just go to the shop I always take my s2k in tacoma. Its on south tacoma way, honda speclialist, a lil past the honda dealership. PM if you got any Qs
I luv my Amuse s2k back to normal!! Shes gets so much attention wherever shes parked hahahaha Its a plus when your hanging out with a girl to and its 85-90 degrees!
SoCalIsMyLife
09-03-2008 01:23 AM
