Side marker not working but turn signal does
Old 02-24-2016, 05:46 AM
  #21
windhund116's Avatar
Received 1,526 Likes on 1,030 Posts
From diagram, looks like maybe several branch points, on the passenger side. Was the fender ever replaced?
Old 02-25-2016, 05:42 AM
  #22
oth
oth's Avatar
When you are checking for +12v, are you using a known good ground? have you checked the
black wire for continuity to ground?
Old 02-25-2016, 02:37 PM
  #23
dlpowered89's Avatar
Yeah. The fender was replaced once before although I am unsure how that can cause this. (Maybe they tried yanking it out without knowing they had to unplug the side marker?)
I've tried looking at 25,26,27,28 you mentioned but it's buried under the fuse so I am not sure how to get in there.
I've tried using the ground wire and the actual ground. I did not get any signal from having the black probe on the actual found so I assumed it was not getting power at all.
Thanks for your help in this guys.
Old 02-25-2016, 05:13 PM
  #24
You sure the side marker light worked after they replaced the fender?
Old 02-25-2016, 09:14 PM
  #25
That I cannot say as it was the first owner that had it replaced. I don't really remember if the side marker worked when I bought the vehicle. (I was paying more attention to the integrity of the vehicle)
Old 02-25-2016, 09:19 PM
  #26
Maybe, the mechanic forgot to re-wire that side marker light.
Old 02-25-2016, 09:52 PM
  #27
I suppose the only way to find out is to take out the fender?
Old 02-25-2016, 10:11 PM
  #28
Unfortunately, yes...
AndyThomason
12-09-2013 01:34 AM
choleaoum
07-05-2013 11:11 AM
ian05s2k
07-14-2011 08:56 AM
markfromaurora
10-18-2010 10:58 PM
Armend17
15
06-15-2010 05:23 PM
Quick Reply: Side marker not working but turn signal does
