shuddering
Sup guys, I have a act clutch and toda flywheel installed on my car. When im moving slowly like say creeping up into a parking spot or reversing, when i push the clutch back in sumtimes the car will shudder and the rpm will drop to like 2 bars but in a second or two adjust back, the whole car shakes though. Is this a problem?
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Sounds normal, due to temp change. It will be amplified by your lightweight flywheel, as the engine now has less inertia to overcome this common occurance.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
the stumbling/stalling is not caused by the flywheel.
it's a common thing that occasionally happens when our ECU gets "confused". it should just go away within a few days.
![wink.gif](https://www.s2ki.com/forums/images/smilies/wink.gif)
Corleone
05-05-2004 01:27 AM
