Should I preventively get new retainers?
Originally Posted by Dave-ROR,Apr 17 2007, 04:09 AM
They are lighter. TI retainers gall and thus become very very thin and may break after 10-20K, however they ae supposed to be an off-road/race part so that's not an issue when used for the purpose they were designed for..
On a car that sees any real mileage, AP2 retainers are the way to go if you have to replace them.
For the OP, if no over-rev was ever done, there's no reason to worry about them, just inspect them during valve adjustments for peace of mind.
Originally Posted by fperra,Apr 17 2007, 08:33 AM
Porsche uses Ti retainers in their cars, and most of them are not off road only.
The Ti Retainers generally available in the aftermarket are NOT coated and ARE off road only. Since this is an S2000 forum I had to assume he wasn't talking about a production Porsche.... I honestly have no idea as my porsche experience is limited to 964's and older, none of which have Ti retainers to my knowledge, but even then my knowledge isn't all that great there.
Originally Posted by Kondor999,Apr 17 2007, 08:25 AM
Thanks for all the great info guys. I must have been crazy not to think of the simple expedient of actually CHECKING the retainers :-).
Anyway, this forces another question:
How much do you think it would be to just visually inspect the retainers? As a mechanic, I'm about a 2/10 (mainly due to lack of tools/garage, not enthusiasm), so I'd prefer to let a pro handle it.
Thanks,
Erich
Thanks,
Erich
Originally Posted by Dave-ROR,Apr 17 2007, 07:08 AM
And I've sure they are coated if that's the case. I should have added a caveat that you can coat them with Nitride which should remove the wear issue, although I have no personal experience with TiN (Titanium Nitride) retainers, but plenty of experience with Ti retainers.
https://www.s2ki.com/forums/index.ph...ic=442653&st=0
I don't know if there is a DIY, but this has pictures on page 2 and 3 of cracked retainers and what they would look like in the car next to a good one.
Well galling is a property of the metal itself, not really the design. Ti will gall whenever there is shifting contact/movement against it, which does happen in a valvetrain. I never said they would fail at 5-10k, but I have seen them (not supertech, never used those) fail close to 20k, and seen some very very thin ones around 20k that haven't failed, but I've also seen some with 20k on them that look brand new.
Irregardless, uncoated Ti retainers SHOULD be inspected for wear during valve adjustments, just in case. I tend to use OEM retainers cause I'm lazy
To inspect retainers, all you need to do is pull the valve cover. No other disassembly needed.
You cannot see the cracks, but the slightest crack will raise the retainers upwards on the keepers.
Study my pics, then do it
Now I just need to get the cover off. I wanted to get my valves adjusted anyway by the dealer. I wonder if they check for this or would be willing to...
Thanks,
Erich
