Should I Be Alarmed About Oil Consumption
Mine drinks it like it's going out of fashion. I'd say about a half litre every 1000km. Performance is good, no smoke, but lots of condensation on cold days. I've just got used to every 5th fillup being about $100. lol.
I have a MY01, and everything I read about it said it should be drinking oil. I've had the car for 2 years now, always checked the oil when I first got her... she just doesn't consume oil, at all.
I use mobil 1 synthetic.
![th_dontknow.gif](https://www.s2ki.com/forums/images/smilies/th_dontknow.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
I calculated what mine is using since i've got her.
Average is 1 liter/5000 km. I feel lucky. 2001 AP1, don't know the history of the car. When was your last valve adjustment? PCV valve good? Have you tried a different oil just to see. I know a lot of Mobile 1 users report this problem.
rev to 9k every day.
Originally Posted by foxy_s2k,May 11 2009, 08:04 AM
Seems there's big variation from car to car. Anyone know what actually causes the oil burning?
![eek3.gif](https://www.s2ki.com/forums/images/smilies/eek3.gif)
I bought the car with 22k miles used with a HOnda Care extended warrentee which thankfully transfered to me the second owner. They pulled the head off and found that i was leaking past the valve guides and rings both, after further inspection they found a couple of the cylinder walls had cracks in them. They replaced the valve guids/seals and mounted the head on top of a brand new complete bottom end from the factory no charge.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
So yes our motors consume oil, especially the early ap1's, is it normal, yes and no. If its bad enough you should figure out why. 1q per 1k miles is the max, but I say if its this bad its not great and you do have an issue that will not get any better over time, I would try and get it handled for free through Honda.
I have a 2002 with 27K miles. Running Mobil 1 10/30. Purchased the car last December and tucked it away for the winter. So far this spring I've put about 1000 miles with frequent forays into 8-9K rpm.
So far, my oil level has not moved at all.
Yes, I'm very happy about that. But, I'll keep checking after every run!
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
2003 here no burning oil. I guess because I am using amsoil 10w30? My integra gsr used to burn 1.5 quarts every 300 miles, which was such a hassle.
Originally Posted by berlinas2k2,May 12 2009, 06:02 PM
I put in about 1/2 quart every 500miles or so, but I'm F/I.
Though that does necessarily mean your cooking it past your rings, could be your valve guides/seals if you have a few miles on her.
