Should FW be resurfaced when installing new clutch
Old 12-17-2004, 08:23 PM
RACER's Avatar
Originally Posted by billman250
This flywheel needs to be "step cut". It would prolly take about .003 to get a 100% cut on the friction surface, hence you would machine the step .003 to preserve the clamping load. If you can find someone who is knowledgeable on cutting flywheels, I'd recommend you cut it.
I had this done to the flywheel from my Del Sol.
Old 12-18-2004, 05:19 AM
Former Sponsor
Gernby's Avatar
What does "step cut" mean? Does it mean that you scrape it in very small steps (like .001") until it is flat?
Wait, looking at the picture again, do you mean that the mounts for the PP need to be scraped too?
Old 12-18-2004, 10:51 AM
Billman250's Avatar
Received 1,396 Likes on 837 Posts
Exactly....A flywheel machine is a precision grinding stone, unlike a brake lathe which cuts with blades. Using a collet type dowel pin remover, you'd pull the dowels, and plane the surface that the pressure plate mounts to in addition to the friction surface. I can do you up one if you like...Just pay cutting and shipping, you can have the FW for free.
Old 12-18-2004, 11:19 AM
Former Sponsor
Gernby's Avatar
Crap. I understand how that would reduce mass slightly without reducing clamping force, but it doesn't sound like something I will be able to find this weekend, and I can't wait for one to be shipped.
Old 12-18-2004, 11:22 AM
Former Sponsor
Gernby's Avatar
Okay, so I guess I will just use sand paper. How many thousands of passes will I need to make to "call it good"?
Old 12-18-2004, 11:54 AM
Billman250's Avatar
Just scuff it enough to break the shine off it...should take 2-4 minutes
Old 12-18-2004, 01:40 PM
Former Sponsor
Gernby's Avatar
At the rate I've been going on this project, I expect it will take 4-6 hours (including smoking, beer drinking, bitching, socializing, and trips to the hardware store).
Old 12-18-2004, 04:23 PM
Intrepid175's Avatar
Around here, I'd call that a conservative estimate!
Best of luck & Drive Safe,
Steve R.
Old 12-18-2004, 07:10 PM
P5744D's Avatar
I didn't like the pedal on the factory setup so when I replaced my clutch I cut it an extra .002 over the factory spec, just a guess at the time but seemed to work well. Pedal is an inch off the floor and no slip with a 6000 rpm drop. I also used a lightened Fidenza flywheel and an ACT street clutch, its awesome. Rev's fast don't miss a shift. but has a few drawbacks if you care! not good in traffic on hills, spins the tires until you get used to it,(could just be the driver). does not make more hp just puts more to the wheels at high rpm's, but sure goes upstairs faster.
Old 12-18-2004, 07:27 PM
Former Sponsor
Gernby's Avatar
The pedal height is easily adjustable without doing anything to the clutch at all.
Quick Reply: Should FW be resurfaced when installing new clutch
