Shock replacement
Koni Yellows, and use the stiff linear bumpstops from here http://www.ground-control-store.com/...php/II=10/CA=1
Used OEM or CR.. cheapest and easiest. Koni's require you to drill out the OEM top hats (8x rose bushings, 4x dust boots), adding time and potentially cost as you destroy some drill bits
