Shifting problem. Help needed **SOLVED**
Old 02-23-2010, 07:00 PM
oocutioo's Avatar
Default Shifting problem. Help needed **SOLVED**
Sometime I shift into 1st gear the car shaked like it hit a speed bump. It happen almost everytime i shift from 1st to 2nd gear and every other gears(the higher the gear the lesser it shake). At first i thought i hit a small speed bump on the road but it was actually from the car itshelf. I can hear the thumbing noise as well.And it happen when i shift at low RPM, if i shift at 4-5k or higher it doesnt shake like that. Anyone know how to fix it and what part need to be replaced? Thanks
P.S I engaged the clutch 100% everytime I shift
BTW it is a 2000 AP1 with almost 100k
Update: I think i solved it with a tranny fluid change. The car drive like brand new now. Thanks everyone. Btw the tranny/engine mounts are still good. i never thought a tranny fluid change make a huge improvement like this.
Old 02-23-2010, 09:23 PM
S2KennyT's Avatar
this "shake" that you're talking about..
do u mean the car feels like it wants to stall??
like a kind of jerking motion forth and back??
Old 02-23-2010, 10:06 PM
estooki's Avatar
is there like a knocking noise?
I think ur shifting at too low rpm
i dont usually shift lower than 3.5, anything lower i get that noise sometimes
oocutioo's Avatar
the car doesnt stall at all as the RPM didnt drop. The shake feel almost like you hit a very small speed bump. I can certainly feel the tranmission wanna jump out of the car but it doesnt. I been driving it like that for about 2k miles
Old 02-23-2010, 10:18 PM
oocutioo's Avatar
yes there is knocking noises. It hard to rev high when stuck in traffics. Will it hurt the tranny if i keep shifting like that?
Old 02-24-2010, 12:11 AM
///RS-2000's Avatar
Could it be that you are releasing the clutch to soon thereby making the car jerk or "stall" sort of? I know this happened to me a lot when I first got my S since it was new to me. I would try replacing the clutch fluid and tranny oil.
Old 02-24-2010, 01:32 AM
Sukeetoshyoo88's Avatar
when going from 1st to 2nd i think it'll help if you keep you clutch at the engagement point for like a second or maybe like half a second, before fully engaging the clutch.
it'll make it alot smoother.
Old 02-24-2010, 04:58 AM
takeshi's Avatar
Define "low RPM".
Old 02-24-2010, 09:17 AM
oocutioo's Avatar
Originally Posted by takeshi,Feb 24 2010, 05:58 AM
Define "low RPM".
when i shift at 3k rpm or lower. im going to change clutch fluid and tranmission fluid to see if there gonna be any improvement
Old 02-24-2010, 09:19 AM
oocutioo's Avatar
no. the shaking happen right when i shift into gear. So the clutch still fully depressed.
Quick Reply: Shifting problem. Help needed **SOLVED**
