shifted 4 to 3 over rev light flashed twice
I think i heared some where in these forums if you over rev you should take off your valve cover and check if some thing is missed up i forgot what. oh yeah and i heared that it takes time for your engine to blow if you missed them up and some times it would even take months for your engine to blow.
https://www.s2ki.com/forums/index.php?showtopic=728941
This just happened to me. Basically it's in your best interest to inspect your valves and your retainers. If you slightly damaged youa retainer, it will break someday causing your valve to fall into your piston. At that point you'll need a new engine. I have my engine partially disassembled in the garage as we speak from this. It wasn't even my freaking fault. :/
What I mean is that in all over-revs you will see the light flashing.. but not all light flashings are over-rev (I see the rev light flashing almost every day in my car)
From what I've been reading a down shift over rev is alot worse than hittng the rev limiter on the up shift.Thus the saying "brakes are cheaper than engines" brake,blip,shift.
However, when you overrev due to a misshift, your ecu can't offer proctection due to a manual mistake, it's like your forcing a lower gear to engage which is deadly to your engine/head etc. So don't misshift! LOL.
To the OP, you have a ticking time bomb in your hands now, it's only a matter of time until the retainer gives up, when is this gonna happend? You never know.. Have it checked.
Originally Posted by Freddy,Sep 11 2009, 07:20 AM
An overrev caused by a misshift is definitely worse than hitting your rev limiter. When you hit 9k (assuming you have an AP1) there's a fuel cut that wont allow you to go any further. This protects your engine from overring.
Originally Posted by deibit,Sep 11 2009, 04:03 AM
There's nothing worse or bad or evil on hitting the ignition-cut while up-shifting (other than losing acceleration/time)
It's pretty remarkable that the F20 can do 9k all day every day without much more fuss than some oil consumption, but one overrev which forces the pistons to move at 10 or maybe 11k rpm for a second will destroy it in time.
Shows how high strung our motors are.
