Sheared a sensor
Sheared a sensor
I've been in the process of replacing my clutch and doing a generally bad job of taking things off I shouldn't be, and I broke a sensor on the side of the block. After looking at the manual I think it's the knock sensor.
I mostly wanted to make sure before I ordered a new one, seeing as they're listed on Majestic Honda at $129.96.
That is quite common and the sensor is very brittle, it has a greenish cap on it. I can't see the image you posted but it is on the driver side of the block near the starter and the only sensor with a green cap.
Originally I was going to replace the manifold and throttle body with a larger ones but I'm going to be moving soon I don't have the money to get them yet. It was a poorly executed idea on my part.
Don't feel bad, that sensor breaks if you sneeze on it.
Wannabes2k2k11
02-12-2014 07:11 PM
