shaving sidemarkers
shaving sidemarkers
i searched for a diy but ill i can find is pics. i know it takes 2 seconds to take it out but 2 problems.
1) willl my blinker blink super fast and how can i fix this?
2) can a body shop easily fix the hole left over or do i need new front fenders?
I'm not sure about the blinker part, but I don't think it will affect it. Also yes a good body shop will be able to patch those holes. They will weld in a piece of metal right there, grind it smooth, then re-paint your whole fenders. If you buy new fenders that hole will be there no matter what, so that would be pointless.
Good Luck!
Good Luck!
Originally Posted by blixhavn,Feb 21 2011, 01:42 PM
seibon fenders dont have the side marker holes
aftermarket low end composite part can be a bitch to prep, the wave, the high and low in the coating. If their fender is anything like my seibon trunk, i wouldn't even bother with it. I wouldn't be surprise if it's about the same weight in finish form.
shaving the blinker you'll need to weld in a plate, grind down, block down and refill all the low point, skipcoat and of course the paint.
Your blinkers will blink faster due to the "missing" resistance it's used to. You can get units that fix this (People who change to LED will know what I'm talking about) but basically it's a resistor pack that tricks the "hyper-flashing system" to trick it into blinking normally - As it blinks fast to alert the driver that there is a bulb out.
As the others have said, new plate welded, ground, repainted for the hole.
