Shaky Shifter
Old 09-09-2004, 08:51 AM
PrimoAP1's Avatar
Thumbs up Shaky Shifter
My shifter vibrates and shakes around quite a bit and I was wondering if there is a nut that can be tightened or a some maintenance I can do to rememdy this.
My car is stock but I noticed that it became worse after I bought the 17" MY04 wheels which obviously have lower profile tires.
Muchos Gracias!
Old 09-09-2004, 09:45 AM
Former Sponsor
Gernby's Avatar
The shifter wiggles because the transmission and engine wiggle. The only thing you can do to reduce it is to install stiffer engine mount bushings and / or install a J's engine damper.
Old 09-09-2004, 11:53 AM
PrimoAP1's Avatar
Thanks gernby... Could it be a sign of maybe a bad stock bushing- cracked?
Old 09-09-2004, 12:27 PM
RazorV3's Avatar
even brand new s2000's have "shaky shifters". its just a characteristic of having the shifter directly connected to the transmission, the transmission sits right under it. its not like a hydraulic or cable actuated shifter.
Old 09-09-2004, 12:52 PM
PrimoAP1's Avatar
I understand this, it just seems to have gotten noticably worse. Although, the roads here in Portland, OR suck and this heightens the problem.
Thanks guys for the help!
Old 09-09-2004, 01:07 PM
r_duff's Avatar
do u mean LINKAGE or cable shifter? is there such a thing as hydraulic shifter? I know we have hydraulic CLUTCH...
Old 09-09-2004, 06:21 PM
RazorV3's Avatar
yes i meant linkage, thanks.
Old 09-09-2004, 06:45 PM
ahbongkadah's Avatar
Wouldn't installing stiffer engine mounts make the vibration more noticable? On my previous car, which was a civic hb with a b18c swap, when i swapped to stiffer mounts the whole car vibrated (yeah the ladies loved it )
Old 09-09-2004, 07:45 PM
mikegarrison's Avatar
Put the car up on jacks and look at the engine mounts. No reason to just guess. I had a shaking shifter, and when I looked at the engine mounts I found one busted.
Old 09-09-2004, 07:47 PM
Stiffer mounts would make the whole car shake more. On the other hand, they would make the shifter shake less.
Quick Reply: Shaky Shifter
