Shaking at 80+mph
Shaking at 80+mph
So ive had some shaking/vibration at higher speeds since ive owned my MY00 s2k, but after reading around some, i figured it was something to do with the axle nut TSB. After doing the TSB it seems i still have shaking/vibration, could it be worn hubs and bearings? Or something else? Anyone else have this?
It could be wheel balance as franky suggested. You can get this if you lost some wheel weights. If your alignment is bad, that could cause this as well. Hitting a pothole hard could cause this. You'd probably see some funky wear on your front tires. Maybe cupping.
my MY04 did the same thing. i felt the vibration at low speeds but on acceleration it would vibrate increasingly harsher. you more than likely need an axle bucket swap. Billman test drove mine and verified the problem. actually he guessed it when I described it to him in a pm. when he took out the axle bucket on my left side he showed me how pitted it was. after he verified they weren't previously swapped he switched them and it now runs as smooth as glass.
