Serpentine Tensioner Shaky After Belt Replacement
Old 06-02-2009, 10:07 PM
iam7head's Avatar
Originally Posted by Mugenboyz,Jun 2 2009, 08:14 PM
After replacing the tensioner, problem remains. I'm just going to leave it alone. Hopefully, the problem will go away.
most car doesn't self heal but..um..
please check the how much slack and where is the arrow aiming at(on the tensioner)
Old 06-03-2009, 07:10 AM
Mugenboyz's Avatar
Yeah the car is an older car with 100k+. The tensioner marker is inside the marked range.
Old 07-09-2009, 10:11 AM
Jason B's Avatar
Where should the mark be? Anyone have a picture of where the mark should typically be at?
Old 07-10-2009, 10:02 AM
SpitfireS's Avatar
Old 07-20-2009, 08:46 AM
Jason B's Avatar
Cool. Thanks for the pic. Is it normal at idle for that part to shake a little right? left to right, very slightly. I've never really looked at it before, but I'm assuming it should, and also the pulled connected to it does the same a little. It's quiet as can be though.
Old 07-20-2009, 10:06 AM
SgtB's Avatar
If your idle has a small lope to it the tensioner will shake. Push the throttle pulley a little and hold it steady in one spot. The shake should stop. You'll notice too, that if you bump the throttle a few times, the tensioner reacts to the torque. All normal. I'd only worry if it looked like it was trying to take flight. I notice higher millage S2000's have a small lump at idle. I'm still trying to figure that one out.
liybzd
05-13-2014 08:40 AM
geared
08-19-2012 06:28 AM
Vinny_GPW-S2K
06-25-2012 01:30 PM
Tugz_S2K
08-05-2006 04:09 PM
Touge Freak
07-21-2005 11:33 AM
Quick Reply: Serpentine Tensioner Shaky After Belt Replacement
