Serpentine belt keeps 'jumping off' track? *with video*
Old 11-07-2013, 09:01 AM
scuderiax8's Avatar
good thing you narrowed it out already good luck and btw which pulley and where did you order it from if i may ask >?
Old 11-07-2013, 09:45 AM
MR.T's Avatar
Originally Posted by s2000Junky
Is the OP referring to the crank pulley in the pic or the idle pulley above it?
I'm gathering the crank pulley.
Old 11-10-2013, 09:53 AM
Kyle is raaddd's Avatar
Originally Posted by MR.T
You're sure it's just the pulley right? From what I've gathered the pulley itself separated from the portion held on by the nut. Car running ok??
Don't know about glueing the pulley on...sounds like a ticking time bomb to me. I'm not totally sure what would happen to a motor if the entire pulley popped off in the middle of an engine rev, but it can't be a good thing.
It definitely isn't the best thing, but thankfully I only have to drive a very very short distance to and from work.
Touge Factory pulley set, found here: http://www.tf-works.com/pulleys-belts-17/
Should arrive tomorrow. Tuesday at the latest.
Correct.
Old 11-12-2013, 05:49 AM
modifry's Avatar
Bear in mind it is a bee-atch to remove the crank pulley unless you have the special crank holder tool. It fits inside the pulley, into the large hex-shaped hole, so you can keep the crankshaft from turning while you use a 3-foot pipe extension on your socket wrench to loosen the bolt. Seriously, it's tight. We spent 2 hours trying to get it off and there was nothing we do do to stop the crankshaft from turning. We put the car in gear, parking brakes on, but there is enough slack in the drive line that you need over half a turn on the bolt to get it to loosen, and you don't have that much room to swing your wrench. We ended up borrowing the tool from my local Honda dealer. I don't think they loan tools as a rule but I happened to know the SM pretty well.
Old 11-12-2013, 08:01 AM
s2000maniac's Avatar
You can rent the tool from NAPA auto parts store.
Old 11-13-2013, 04:40 PM
I rented the tool, no way I could have possibly done it without!!
Here is the original pulley after removed, and a visual representation of it being broken.
But, we are all good now!
Just drove it, such a good feeling knowing that my car is safe!
Thank you all for your help, I really appreciate it.
Old 11-15-2013, 09:59 PM
pemex70's Avatar
^ did you notice any gains with the new set?
Old 11-16-2013, 09:06 AM
boyguan's Avatar
Be careful since this does not have the balancer
Your old pulley was shot
Old 11-16-2013, 01:18 PM
postman's Avatar
Put an OEM crank pulley on that asap. Just trust me.
Old 11-17-2013, 08:53 AM
Slows2k's Avatar
Not the 1st Honda crank pulley to come apart, 1st S2000 pulley that I've seen though.
Quick Reply: Serpentine belt keeps 'jumping off' track? *with video*
