Serious Transmission Knock, ect... :(
Update: I replaced the tct with bill's unit and nothing changed at all. So, I'm assuming my tct was fine - MY00 @ 95k miles,, is that unusual? I left the new one in, might as well. Then, today, I had the trans dropped and found my old OIL CAP lodged on top. So, I fixed my rattle - that cap would have never come loose of its spot I don't think, so this was my only real option. Someone suggested it, and I thought about it but didnt really think it was possible. Well, that was annoying, but thanks for your help. Peace.
WD
WD
wow...awesome!
Lost oil cap has been a problem for years on the s2k. If it falls behind the engine, it will sit on top of the transmission and will never come out until you take it out. Causes a nasty knocking against the transmission tunnel. Glad you found it
there are motor mounts as well as transmission mounts that could be the cause. I would lean more towards a mount before looking to replace the tranny, especially if the shifts are good and smooth. You just posted up on this so I would wait for more replies as one of the long term owners that know the S really well, like Billman, can chime in.
Did you happen to lose an oil cap recently?? They get lodged in between the transmiision and the firewall
I can't believe Walmart changes oil.
I can't believe anyone would dare bring their car there.
I'd check your oil filter, it will likely be next to fall off.
It must be nice to add a profession to your current empire without any experience at all in the field. As long as the bottom line shows profits that exceed automotive damage claims, who's give a crap right?
