Which sensor drives the cooling fan [2006]?
My cooling fan doesn’t switch on with temperature, and to stop from overheating I need to run the A/C. Which cooling sensor runs the fan? The one in the radiator, or the one in the intake manifold?
https://www.hondapartsonline.net/oem...ic-37870raaa01
https://www.hondapartsonline.net/oem...ta-37870plc004
Edit: Code is P2183 “Coolant Sensor #2”, best guess at this point is the sensor in the radiator.
