Secondary Air Pump P0410 P0411
possable air pump it is bad disconnect it and try going from Batt to air pump with test leads that will answer 70% the other is make sure the air hose to and from air poump not kinked or restricted it airflow senstive, then 3rd is posble relay or fuse is gone bad
Originally Posted by skurge' timestamp='1311774161' post='20820033
[quote name='gabeS2000' timestamp='1311746183' post='20819326']
I got the code P0410 Secondary air inj malf.
Now i need help i know the price $680ish
now if i dont fix this will this mess up the Engine, Miles Per Gallon anything..
Also if anybody has one for sale used or new for a better price.
Thanks..
Thanks..
there is an eliminator that was posted on here recently, just ordered one myself last night
[/quote]
I was plagued by the CEL for over a year on my '02 S2000. It was throwing out a P0410. In the meantime I was having intermittent problems starting the engine due to a flakey Immobilizer unit. Finally I had to tow it home on a flatbed. The dealership replaced the immobilizer unit (wasn't all that cheap). They said it would cost me around $1200.00 to repair the P0410 problem or I could just live with it, as it was not performance affecting. I chose to live with it for now. That was a week ago. Last night I erased the code. This morning I took it for a spin, over a hundred miles and the CEL never returned! Before, it would come back on within a few miles. I'm holding my breath. What a relief so far. Could it be coincidental? Fixing one problem may have cleared another OBDII code? At least now I can go get tabs!
There is no way fixing your immobilizer cured your P0410 or P0411.
NOW there finally is an air pump simulator kit, to rid the car of a P0410 or P0411. I would fix the basics first as this is a VERY common code.
Should it be deemed costly, this "Izzy Kit" might be your best bet. I have installed many with 100% success:
http://www.google.com/url?sa=t&rct=j...49478099,d.dmg
