Second Gear Crunch
Old 10-01-2013, 03:56 AM
  #21
iamxpl's Avatar
time to check the shifter bushings. did you change your clutch fluid ? you can just gravity bleed it as well. if youve never changed it, that fluid is probably black and well over due.
Old 10-24-2013, 09:26 AM
  #22
flipboi4o1's Avatar
I haven't gravity bled my clutch fluid but I have done the turkey baster technique on the reservoir.
Old 10-24-2013, 11:29 AM
  #23
chino101's Avatar
Another piece of advice that was given by Billman was to rev to about 5k RPM before shifting. I rev to 4,500 RMP gradually before shifting from 1st to 2nd, and the crunch is significantly reduce or not even there; there is a slight notchiness but goes away aft 15 min or 10 miles of driving. Good luck!
Old 10-24-2013, 11:39 AM
  #24
jimboslice's Avatar
I've read the same thing and follow that logic now. He basically said you need to shift faster and at higher RPM. I shift at 5k quickly and smoothly, and the notchiness/crunch is gone.
Old 10-24-2013, 11:48 AM
  #25
flipboi4o1's Avatar
Does that also apply for AP2? Worst case scenario, I hope it isn't that rusted spline situation I've stumbled upon in this forum.
Old 10-24-2013, 12:32 PM
  #26
chino101's Avatar
Originally Posted by flipboi4o1
Originally Posted by jimboslice' timestamp='1382643587' post='22844766
[quote name='chino101' timestamp='1382642997' post='22844746']
[/quote]
I also have an AP2.
Old 10-24-2013, 12:34 PM
  #27
jimboslice's Avatar
[/quote]
works for me and I drive a 2007. I also adjusted my clutch play recently and I think that helped a bunch too.
It's my understanding that it's supposed to feel somewhat notchy, since there's no linkage or cables to dampen the feeling of the shifter/gearbox.
s2kcanuck
06-09-2018 06:24 AM
flipboi4o1
10-10-2013 07:59 AM
reedntrack
06-29-2007 12:18 PM
Quick Reply: Second Gear Crunch
