Second Gear Crunch
Second Gear Crunch
This is my very first forum and I need help looking for answers..
There's probably many threads out there but i wanna try to get some answers on my own also...
I have a 2004 Honda S2000 Ap2. Lately I've been noticing a crunchy if not grinding sound when shifting in to 2nd gear. This eventually goes away after 10-20 minutes of driving and the shifter feels buttery smooth. Anyone know what could be the cause of it or a way to fix it?
Additional info:
1. I live in northern USA in the New England area so it gets pretty cold during fall/winter. (its late September now)
2. I just recently changed transmission fluid a few days ago to Honda MTL (silver bottle green label)
3. Crunchy sound happens only when I'm moving and shifting to 2nd. When its parked, there are no issues
4. clutch is fully pressed to the floor
5. tried granny shifting (slow shifting)
6. tried double clutching (helps a little but doesn't always work)
7. Daily driven. Not track
8. currently 55k miles
Additional info:
Additional info:
Additional info:
change your clutch fluid. you might not be engaging fully. it takes 2 mins to do. change your trans fluid. warm the car up by driving lightly in gear. once warmed up try shifting higher up in the RPM. youll notice the car shifts much easier.
It is a known issue with some S2000s. It usually occurs when the drivetrain is still cold (i.e. not up to operational temperature). A tranmission fluid change usually helps. The Honda MTF is actually pretty good - I have had only that in my car and it is has no issues. Change it often and you should be better. There is a TSB On the second gear grind as well, but it was for AP1s:
https://www.s2ki.com/s2000/topic/275...into-2nd-gear/
I'll try changing my clutch fluid next. Is there any other possible causes for the crunch that I could possible look into? Hopefully there's nothing too serious.
Also, would a differential fluid help with this problem? I've heard good things about Amsoil severe gear 75w90 and 75w110 browsing the internet.
1. I feel your pain; almost didn't buy my S April 2010 b/c of it.
2. Tried the newer Honda MTF, seemed to help a little; tried GM Synchromesh next year, seemed to help a little more, went to Amsoil the next two years, seemed to be a little better.
3. Just for a change, I might try a mix of Honda MTF and Amsoil next time; I'm due next Spring.
4. It doesn't do it consistently, and not when I'm winding it out, but when "just driving."
i personally use Amsoil for diff and trans. syncromesh for trans and severe gear 110 for the rear. change the clutch fluids first. if the viscosity of the fluid has gone done it will not properly work and engagement can be compromised. and it could just be due to the cold.also try looking into changing the bushings in the shifter. thats also another fix from what i remember. keep us posted
Proper clutch rod adjustment under the dash will help greatly.
DO NOT follow the book, just follow the guidelines here in the forum. Search zero freeplay.
I use the Amsoil 5w30 synthetic MTF in my tranny and it solved any low temp grinding I had. amazing stuff....don't put 75w90 in the transmission its not designed for a heavier oil. However the diff will do good with the Amsoil SG 75w90. I use all Amsoil now from the motor back and im happy with Amsoil products..
