Second Comptech SC dyno tuning with ESM installed
Old 04-30-2003, 04:04 PM
Reignman's Avatar
Default Second Comptech SC dyno tuning with ESM installed
Well I was able to get my car in to the dyno today. Last time the guy couldn't even tune it because any positive settings on the V-AFC would make the ECU go crazy. This time I had the ESM installed and set the voltage at 2.6. The guy had a pretty tough time trying to get the A/F ratio smoothed out with the V-AFC because it would run rich at 3500rpm and at 6000rpm. The problem was after he went over +10 the power would drop because the ECU would be fighting with the V-AFC. After seeing many of the V-AFC settings posted on here I was wondering because he used all positive numbers (adding fuel) and most I have seen posted here use negative numbers. I think the best thing to do would be to add more fuel pressure using the FPR and then I can use negative numbers on the V-AFC which will hopefully smooth out the A/F ratio a bit more and the V-AFC wont have a conflict with the ECU.
I was also surprised because it showed that I was only running 4.1 psi boost max and I thought that the Comptech with stock pulley ran at 6 psi. Does anyone know why it would be running such low boost? Im guessing the difference in 2 psi of boost is why Im dynoing lower then most with the Comptech SC. Below is my dyno chart. I got up to 270hp and 156tq and gained about 7hp after the V-AFC was tuned.
Horsepower / Torque
Air / Fuel Ratio:
Old 04-30-2003, 04:26 PM
Sideways's Avatar
Check your belt tightness.
Old 04-30-2003, 04:31 PM
Reignman's Avatar
The belt is pretty tight. It doesnt give much when I put pressure on it and the belt is only a month old.
Old 04-30-2003, 05:59 PM
payyourtoll's Avatar
you ran 270whp with only 4.1 boost? sounds low. How were you measuring your boost?
Old 04-30-2003, 06:16 PM
Reignman's Avatar
[QUOTE]Originally posted by payyourtoll
[B]you ran 270whp with only 4.1 boost?
Old 04-30-2003, 08:32 PM
koejing's Avatar
Reign,
You should have the ESM set at 2.9 Volts. It should arrive pre-set at this voltage. I would re-set it to 2.9V and re-tune.
Old 04-30-2003, 09:35 PM
Reignman's Avatar
[QUOTE]Originally posted by koejing
[B]Reign,
Old 05-01-2003, 03:32 AM
Yellow Streak's Avatar
Do you have any other alternatives for tuning your car in your area? Are there some shops that have experience with a V-AFC and a Comptech supercharger? I am concerned that a) your tuner didn't know not to run positive settings on a V-AFC and b) your A/F ratios are all over the chart (and dangerously lean in some areas).
If you can graph boost, my guess is that you will find a big drop somewhere and then a spike. The only way a Comptech SC will only put out 4.1 PSI is if your air cleaner is really plugged, you are leaking boost somewhere (couplers, BPV stuck open, etc) or the belt is slipping.
-YS
Old 05-01-2003, 05:50 AM
TepEvan's Avatar
look at that graph, i'm pretty sure that the belt is slipping; but I agree with YS, you should take it to another shop.
Old 05-01-2003, 06:58 AM
Reignman's Avatar
[QUOTE]Originally posted by Yellow Streak
[B]Do you have any other alternatives for tuning your car in your area?
Quick Reply: Second Comptech SC dyno tuning with ESM installed
