SECOND BEST Oil filter
#21
Having fun reading the FAQ and Search results -- OK, that's a lie, not fun at all. "Oil Filter" results in 40 pages of topics, some of which are simply links to generic analyses of filters in general. Sure to spark a liveley debate, but a simple list of "we advise these" filters not forthcoming.
Went to dealers over the weekend for OEM filters for the S2K and the RSX-S; same manufacturer, more or less, similar displacement and HP output. The Acura dealer sold me one for $8.80, up from $7.10 two years ago, washer included. Honda dealer charged a few pennines under $20 once the 67-cent washer was added in, up from $12.00 (exact) two years ago.
Sheesh! Well, I presume a little more search will find me a S2Ki-supporting reseller that will get me 20% off OEM in bulk, nice enough (hints as to whom that might be welcome). That said, alternatives that are of high quality are of interest. No, not Fram (that's not funny!); I am running the Wix air filer that I found out about here on S2Ki -- thanks by the way -- and similar input for the oil filter would be great. especially if it included brand, part #, and source (local chains or on-line).
I have been using OEM filters and Mobil one on all vehicles for decades, but right now I'm looking at $45 in materials only for an oil change... really?
http://www.hondapartscheap.com/southbay/jsp/prddisplay.jsp?hidSwitch=Switch&hidIrno=|008&catcg ry1=S2000&catcgry2=2004&catcgry3=2DR+S2000&catcgry 4=KA6MT&catcgry5=AIR+CLEANER&vinsrch=no&ListAll=&p rdrefno=&act=&count=0&quantity=0
i dont see how spending $45 on an oil change is an issue... thats a pretty good price to pay and unless you drive like crazy youre only spending that $45 every 4-6 months. With an OEM oil filter being $10 and an aftermarket being about $8, you save 2 dollars every 4ish months or $6 per year
and youre running a wix air filter for what benefit? to spend $25 instead of $27 for an oem? this saves you $2 every 1-1.5 years depending your driving habits.
if the small amount of cost difference between OEM maintenance items and off brands is an issue for you, maybe look into making some extra cash to cover the costs. if your saving about $8 per year with after market items, you can make this money back somewhat easily to afford the OEM stuff. one idea off of the top of my head would be to offer one your neighbors a once per year lawn mowing service. if you mowed one lawn per year at a rate of $8 per mow, this would come out to... $8! - - - enough to maintain your car with OEM filters for 1 year. if you dont feel like doing that much work, you could try cost cutting in your personal life. heres another idea off the top of my head... buy 1 less pair of underwear over a 1 year span, this will save some serious cash, you might have enough left over to buy some lucky girl a burger from the dollar menu.
#22
IIRC the oil pressure max's out at 125 psi around 5000 rpm, using a 30 weight.
IOW, after 5k rpm the oil pump is in bypass.
Isn't it the filter media that creates the pressure difference and the amount of media that determines the service interval, IOW how much dirt it can hold without blocking?
If that is true - I'm asking - a bigger filter just gives you a longer service interval, not better filtration and/or less oil pressure drop by default.
Another filter media might give better filtration at the cost of flow and a higher pressure drop, more media would make no difference?
I'm not an oil filter engineer, so I'm just sticking with the OEM PCX.
Btw.. the aftermarket car part industry thrives on people that are sure their car needs performance upgrades, marketing playes a huge role here.
Most claims are not proven, are statistic noise at best.
#23
I run Mobil 1 and OEM filter also. It maybe $45, which is about a tank of gas, for you now but the filter runs two oil intervals. Good price over the life of it.
I look at cost closely too, 166K on a 06, I'm dropping oil every other month and go still go with OEM.
Also request a discount from the dealer, doesn't hurt to ask, I get one and only because I asked if they price match.
#24
.........Isn't it the filter media that creates the pressure difference and the amount of media that determines the service interval, IOW how much dirt it can hold without blocking?
Another filter media might give better filtration at the cost of flow and a higher pressure drop, more media would make no difference?........
You could use a better filter media(smaller micron rating)with a larger filter and still supply your engine with 100% of the oil it needs, but you would not want to go overboard without knowing the gallons/minute the filter will flow @ whatever psi your vehicle needs.
I put 3k to 4k miles a month on my "S" and on my next oil change I'll get a UOA after 150% as shown by the engine oil life indicator. I just changed the oil and filter so it will take me 3 to 4 months but we have some drives planed so I will post the results when I get them.
I have never said that the stock filter(or any other) was bad, I just think I can do better than Honda because I don't have to worry what it cost me since I buy 6 at a time not 60,000.
I appreciate the civil discussion we have had on this because I know how fast this could have degraded as many post have in the past when its about GOD forgive oil or filters.
ROD
#25
$45 is about what I spent, to the penny, for oil & filter. Sure, compared to a new engine, it's a trifle but a 62.5% cost increase over 24 months from the exact same parts counter?
#26
Running the Mobil 1 Syn, I also run the maintenance minder to 1000 miles over, which is about a little over a week in terms of my driving.
#27
The OEM PCX filter is the only way to go. Even if you save a couple bucks every 3000-5000 miles, is it really worth the risk of using a filter that will likely bypass under VTEC? I'd stick with the OEM PCX filter if it cost 3 times as much. It's a quality filter, it's well made, it's specifically made for the S2000, and oh ya... it's actually pretty cheap.
