Scraping sound coming from Rear while driving?
Old 07-21-2012, 07:16 AM
Lookincrazy's Avatar
Originally Posted by franky
To test if its the bearing, lift the car up until the wheel is off the ground. hold the wheel at 9 n 3 o' clock n tilt the wheel side to side for movement. Then hold at 12 n 6 o'clock n tilt it up n down for movement. It theres movement then wheel bearing is bad.
I have been meaning to do that yesterday, but my work hours haven't allowed me too. I will today.
Old 07-21-2012, 07:22 AM
Originally Posted by apme123
where in SoCal are you, I live in west LA and would be more then happy to help you out with the diagnostic, the most common problem is the wheel bearing and hub that go out, this is caused due to the axle nut not being tightened all the way and is very easy to diagnose.
I'm in Burbank. I had the issue with the hub nut being loose a few months ago. I fixed that by torquing to 220 ft-lbs. This popped up all of a sudden. My friend has a shop, i'm probably going to run it over there today and see if we can narrow it down.
I do appreciate you wanting to give me a hand. If i can't diagnose it today, i will send you a PM.
After further investigation it sounds like its coming from right under the car, driveshaft area maybe.
Again thanks for reaching out to me.
Old 07-21-2012, 11:35 AM
apme123's Avatar
great, let me know
Old 09-06-2012, 12:41 PM
LAp1's Avatar
my car is making the EXACT noise as the one in this video...what was your solution?
Old 09-06-2012, 01:01 PM
tom153's Avatar
New hub and wheel bearing.
Old 09-06-2012, 01:21 PM
LAp1's Avatar
Thankyou man
Old 10-06-2015, 08:43 AM
tr1xst3r's Avatar
Just found this thread, as described in the video - exact same sound.
Thank you so much.
toneekay
01-17-2019 11:21 AM
speakeasy2009
05-28-2013 02:56 PM
bryanlamb
08-21-2011 01:11 PM
gopedjumper
07-02-2011 02:21 AM
toniotran
01-11-2009 06:36 PM
Quick Reply: Scraping sound coming from Rear while driving?
