This is scaring me
This is scaring me
Yesterday I was exiting the parking lot of a gas station, and I had it in first gear because I was getting ready to get on the highway, and I was at around 3k rpm, then I pressed the gas a little harder and I was at 4k and my car started jerking like crazy. It felt like it was about to stall, but I was at high rpm's. This has happened to me before 2 or 3 times, one time in bumper to bumper traffic, and several times while going up a parking garage one night.
When you are in first gear, sometimes you can get into the following cycle:
1) foot taps throttle
2) car surges forward
3) foot comes off throttle because car surged forward
4) car slows down, because foot is off throttle
5) foot comes forward because car slows down --> 2)
You can't feel your foot going on and off the throttle, but that's what's happening.
I think mikegarrison is right. I've had this happen to me a couple times in similar situations like the ones you described, and simply attributed it to my own fault. I'm pretty sure it's nothing mechanical, even though the first gear on my 2001 S can be a little finicky at times. I just make sure I ease it into first gear as much as the situation allows and make sure that the gear is engaged before I let 'er rip. If you get that bucking, I think the best thing is to let off the gas and engae the clutch until order is restored (correct me if I'm wrong anyone) Hope this helps even a little...
Aright thanks. I was worrying and thinking it was the car. I can't tell at all that I'm pressing the gas and letting go, but I guess that's what could be happening. I do know that whenever that happens I just press in the clutch again and start over and the car moves just fine.
Originally Posted by xviper,Jan 14 2005, 02:17 PM
It may this phenomenon called "bucking":
http://forums.s2ki.com/forums/index.php?showtopic=57405
But that makes it "driver error", so people don't want to suspect it.
Originally Posted by mikegarrison,Jan 14 2005, 02:28 PM
That thread is full of very amusing theories, all of which are besides the point until the very last guy chimes in. The actual oscilation has nothing particularly to do with the airbox or the throttle or the electronics or any of that. It's an interaction between the response of the foot to the movement of the car and the response of the car to the movement of the foot.
Originally Posted by mikegarrison,Jan 14 2005, 03:45 PM
Pilot-induced oscilation, perhaps? I don't know for sure if this is your problem, but it's a possibility.
First gear throttle operations, especially in heavy traffic, takes more than a little finesse. Next time you get into this, just let off the gas and grab the clutch. When the car settles down, "gently" ease out on the clutch and try again. Don't feel bad about it. It's something that will catch almost everyone, sooner or later.
Drive Safe,
Steve R.
