Saved 13lbs for $140! (Odyssey Battery)
Old 03-27-2002 | 11:14 AM
  #41
krazik's Avatar
Administrator
On Odyessy's site they say that the jacket is for heat resistance. Being that you are so close to the header I wouldn't want to risk it personally. Now if you wanted to mount the battery somewhere else like the trunk or under a seat the 625 might be perfect.
Old 03-27-2002 | 11:33 AM
  #42
vapors2k's Avatar
my friend raised an important question, for cars running higher compression or forced induction, the battery might not supply enough cold cranking amps to start. Not sure even though most of you are not having any problems with it, any of you guys running the comptech SC use one these batteries with below 300 CCA???
Old 03-27-2002 | 11:36 AM
  #43
vapors2k's Avatar
BTW, his set-up was a 13:1 motor, already been proven that our 11:1 motors are fine with the low CCA batteries.
Old 03-28-2002 | 07:17 PM
  #44
DMENACE021's Avatar
I see alot of model #'s and prices being thrown around on this battery issue. I am really interested. Can someone tell me which will be the best battery brand and model would be best for an S2000 with stock factory alarm and stock radio, i only have added performance mods like Intake and Exhaust.
Old 03-28-2002 | 08:26 PM
  #45
krazik's Avatar
Administrator
DM:
I think its pretty clear the 680 is the simplest and most effective solution. If you want less weight and more hassle there are other options.
Old 03-29-2002 | 05:57 AM
  #46
E30M3's Avatar
I use the 680 on my M3 without issue. BUT there is no extra capacity to gloss over inadvertent things like leaving stuff on, or lengthy storage. They can safely be deep discharged so for storage you don't have to use a trickle charger or whatever. The 680 is also successfully used by some of the NSX folks. On the CCA thing, remember that there is a time factor. Briefly batteries can put out more than that amount.
Stan
Old 03-29-2002 | 07:09 AM
  #47
Prolene's Avatar
[QUOTE]Originally posted by E30M3
[B]I use the 680 on my M3 without issue.
Old 03-29-2002 | 02:56 PM
  #48
DMENACE021's Avatar
...man this is confusing, I dont know which one to get.
Old 03-29-2002 | 03:42 PM
  #49
Prolene's Avatar
I recommend the PC680, as does krazik.
Old 03-29-2002 | 05:08 PM
  #50
jschmidt's Avatar
I guess everyone knows this is only a good idea if you live in a fair weather year-around area.
Quick Reply: Saved 13lbs for $140! (Odyssey Battery)
