Saved 13lbs for $140! (Odyssey Battery)
#21
I didn;t bother with the automotive terminals.
I used the allen screw that was provided with it. Just take the bolt and nut off the end of the stock battery connectors, and squeeze them jiust a tad bit flat and then you can use the allen bolt for a very nice and well attached connection.
#27
The only significant size difference between the 680 and 545 is the 680 is about an inch taller.
SilverSurfer and I were looking at them trying to figure out which one you had.
#30
spider, I was able to use all of the stock mounting hardware. With the 680 you have about a 1/4-1/8th inch of "spare" thread on the mounting screws. It does look a little odd with the ~2" of bolt sticking up tho
I might cut them back.
