Safety of X-braces
Safety of X-braces
Most cars are designed so the engine/transmission drops under the care during a head on collision rather than impinge on the passenger compartment. The DiGrappa, Comptec, and Whiteline X-braces appear to have potential to interfere with this during a crash. The Cusco 3 point brace seems somewhat less inclined to do so. Any thoughts from the informed?
I'm with turbo_pwr. Adding an Xbrace changes the engineering as honda intended it. That's the only thing you know. Without a real crash test anything else is pointless speculation.
If you worry about it, don't install it. I'm planning on getting one but, I also believe the probability of a full speed, head on colision's low enough that it's a non-issue. I might be wrong and it might kill me but, that's just how probability is. Sometimes your number comes up.
A head on collision's far safer than getting T boned. I'd worry more about that.
I think is has been more then 1.5 years since this topic last came up. From a 5yr member non the less this time. I even had to reread the first post, "DiGrappa", man that was a long time ago, years.
Again, I agree with Dan on this one.The braces are designed for for strength in the corners and not under the motor. Think of it like a board, easy to break if hit in the middle, hard is hit in the edges.
if you get into an accident where your engine and transmission were to break off and drop under the car... an x-brace will be the last last kind of brace you will be worrying about.
