s2k dont want to start
a couple of days ago my s2k started makeinga knocking noise thought it was the valves or a rod bearing. went to take it to a shop and it wont start the fuelpump nothing wants to turn on all it does is act like the battery has no cold canking amps it just 12 volts. tried to jump it still does the same thing does anyone know what it could be......
i have the same problem... s2k wont start..but my battery is bad..and im goin to replace it..but when i try to jump it..same thing.. it will just crank over like it wants to start...it acts like it wants to start but it doesn't..and then i replaced the spark plugs becauset they looked fouled..but now i dunno what to do....
i was driving home one night..and then just downed it to 3rd then it just started to run really rough and felt like it was missfiring....CEL like was flashing ..and when i would stop it would completly die..and then when i try to start it up again..it would crank and crank and crank then start up after... then i parked it and tried jumping it the next day.. it wont start..
i need help...
PLS HELP
i need help...
PLS HELP
i need help...
PLS HELP
i need help...
PLS HELP
But...how fast were you going when you "just downed it to 3rd"? And what mods to your car?
You may have over-revved the car when you downshifted and bent a valve.
Originally Posted by jyeung528,Dec 30 2007, 12:19 AM
both of you guys need to do a compression/leakdown test...to rule out major issues/damage.
However, the "just downed it to third" thing is probably the real cause for "1stook2c". Don't be in denial on this sort of thing. If you overreved the engine it may be fixable right now. If you keep driving it with damage, you are bound to lose the entire engine.
Remove the battery entirely and hook the car up to a battery you know is good to see if you can get power.
As for the knocking...if your car is making that kind of sound, it would probably be best to tow it so as not to damage the engine further. Otherwise, a rod knock might turn into a cracked block should the rod let go and get shoved out the side of the block.
i need help...
PLS HELP
i need help...
PLS HELP
Originally Posted by mikegarrison,Dec 30 2007, 09:39 AM
Both of you guys need to try a fresh and new battery first. That's a lot cheaper than a compression and leakdown test, and it's the number one cause of "car won't start" problems.
