s2000 will not start
OK i have a 02 S i just purchased it from a guy who broke a valve! I replaced the valves retainers springs keepers, and head gasket! Car started right up! It being the first time i ever drove the car or and s2k i took it easy let it warm up then tried to see what it would do! It had a weird rev limiter at 3 thousand rpms. I thought nothing of it so when i parked it after only driving it 4 miles, the next morning it would not start! I am geting fuel, no fire! There are no codes! I was wondering if someone has had similar problems! PLEASE HELP my GF wants to look at christmas lights with the top down!
its not getting fire, i have an in line spark tester on one of the IC's and it does not spark! The compression is fine i did a valve job lapped all the valves and leak tested them! And it was running fine!
ok i bypassed the spark tester and just put an old plugg in the end of every IC! It is firing and def getting fuel! What conrols the timing assuming i have good compression
It had a weird rev limiter at 3 thousand rpms. What conrols the timing?
The Crank Angle Sensor and the two Cam Sensor tells the ECU where things are, and the ECU controls timing. I have seen something like this before, it was the Crank Angle Sensor wiring to a Black Box Timing controller. But the car ran, but only to 3K and it generated CEL codes. So if your check engine light on?
forgive my ignorance CEL?
no codes present i have a snap on solus
there was an engine light on but i before i got to read codes i put a new battery on! OH and it is firing and gettin fuel but no start
Check fuses. Also, get a mechanic's stethoscope and listen to the injectors firing (clicking) as someone's cranking the engine.
I discovered that if the fuel pump fuse is out, ECU (Engine Control Unit) will not get any power at all. If found this out when I was troubleshooting Emanage harness.
Do you have correct spark plugs? This car is kinda picky about it's sparkys.
If you jump pins #4 and #9 on OBDII connector, and turn ignition on, the Check Engine light will start flashing out 2-digit codes which might point you in the right direction. Just post them here. Or better yet, pull them with a scan tool.
As mentioned above, check all grounds and ground lugs that they're tight.
