S2000 Vibration on decel and some accel
Basically my S2000 drives great and my cousin's has this horrible vibration on decel and on accel in lower RPM. I have NFI what the problem is. Pretty sure it isn't clutch buzz as mine makes the typical clutch buzz sound. Have replaced diff rear mounts (fronts look fine), driveshaft.. Might try engine mounts next (they look fine though)... Could it be the actual diff?
It feels like its coming from the middle / rear of the car. The noise goes away after a certain rpm on the way down and way up (low rpm).
Car isn't lowered.
Vid below thanks
[media]http://youtu.be/O4chCn5cH3c[/media]
Car isn't lowered.
Vid below thanks
Isn't jerky at all, just the vibration. We swapped the whole driveshaft / CVs etc with a known good car so isn't that.
I honestly think its clutch now, its slipping just a little bit at high rpm.
Swap the CV buckets, cheap and you will be able to see if they are pitted once you get them off.
https://www.s2ki.com/s2000/topic/241...diy-with-pics/
dripking07
09-01-2010 07:02 AM
