>> S2000 Valve Adjustment, Step-By-Step
#81
Banned
I just did mine, excellent thread destiny, and thanks to xviper for helping me with other stuff. Gernby, I noticed that you said since you set your valves to .007 and .009 you need to check them more often. Is this to ensure that they do not get tighter and burn a valve? Or is it to ensure that they do not get looser and stay at .007 .009 since it may be harder to keep them there?
#84
Originally posted by s2000turbo
How much cost at the dealer to do this valve adjustment? anybody know?
#85
Banned
gernby..... I read in one of your other posts on a different thread, that the first time you adjusted your valves you checked in the wrong area causing them to have a LARGE clearance and loss of power. Just curious, when you checked them in the correct area, just HOW off were they, maybe .012 exhaust and .011 intake ?
#86
Banned
I agree with gernby, not only does the dealer tend to not touch the valves period, but they tend to only look for valves which are WAY out of spec and adjust them, rather than adjusting all the valves to the proper spec.
#89
Originally posted by hondaS2001
wow..... so that probably means you were at something like .011 and .014?
#90
Banned
wow no wonder you felt a power loss.... I did mine twice, once at .008 and .010 then a few days later at .009 and .011. At .008 and .010 it feels a TINY bit more powerful in the midrange, runs a little smoother, but I wanted them a little on the loose side, but still within spec, do you think this is bad gernby?
