S2000 Torque Steer?
S2000 Torque Steer?
My friend has a 2002 s2000 and when you are coasting along in any gear and press the gas the car pulls really hard to the right. As soon as you let off it pulls really hard back to the left. My s2000 never did this and the only time i have seen this is in fwd. Any ideas? By the way there are no odd sounds when the car does this.
Thanks you guys. that is exactly what it was. The LF and RR barely even showed anything on the TPG. Im guessing that he has runflats on it because with pressures that low they should have been sitting on the ground. But i couldnt visualy tell a diffrence after they were inflated correctly. However the car no longer pulls. Thanks again for the quick fix.
Originally Posted by CoralDoc' date='Dec 28 2008, 07:45 PM
Be sure to figure out why the tires were so low. I bet there is still something stuck in the tires.
that green slime shit works. might throw off bal. for a while but if youre not tracking/ trying to find a quick fix....it works wonders.
im sure the guys who change your tires after will hate you though.
