S2000 Ticking noise
S2000 Ticking noise
Hey guys recently i started to notice some of what i believed was noise coming from the timing chain so i decided to replace the timing chain tensioer as i thought this would fix my problem. Unfortunetly the ticking noise did not go away!! Im going to adjust the the valves next week sometime just to make sure thats not the culprit here. Heres a link to a video of my car, id like to know what others think. Video was taken after my car was warmed up and drivin around.
http://youtu.be/wqTp2djm0k4
Would be interested in hearing the sound when revving also
Originally Posted by shanepotter' timestamp='1453020526' post='23854505
Oil is completely full, i changed it when i put the new timing chain tensioner in. And yea im really hoping the valve adjustment gets rid of the noise.
https://www.youtube.com/watch?v=M9rRW0xQOVs
Originally Posted by Soviet' timestamp='1453084856' post='23855153
[quote name='shanepotter' timestamp='1453020526' post='23854505']
[/quote]
Sounds like really loose valves, or potentially a missing valve adjustment nut.
Your car sounds a lot like mine did a while ago. Check it out. Adjust those valves ASAP!
[media]http://www.youtube.com/watch?v=CTpPGoKME18[/media]
[/quote]
try not to drive it too hard or maybe even at all until you do the adjustment, if you can. Not that that's NECESSARY strictly speaking, but I just had a similar issue, and should have done a valve adjustment sooner but instead the lock nut broke loose and the valve dropped and my engine is pretty messed up right now and in need of replacement. It's totally unlikely that'll happen because I'm still not sure what EXACTLY caused my valve to drop but just do the adjustment first anyway Good luck!
Nimbus, even if the adjustment nut fell off, the valve associated with it will not fall into the combustion chamber. If anything, the lash tolerance = too wide and the valve won't open at all.
The valve retainer and/or cotters would need to fail, in order for the valve to drop into the cylinder. Also, if you set the cam timing off --- you can run the risk of the piston hitting the valve and causing damage. Mechanical over-revving may cause damage to the retainer or float the valve.
It can go either way, the screw is tapered at the bottom so it cannot back out with the rocker arms installed. It can also tighten itself all the way however.
