S2000 Suspension Question
Can the S2000's suspension parts like control arms, bushings, etc. bend even slightly or will they break under the slightest of strain due to the fact that the majority of the suspension parts are made from brittle cast iron?
Originally Posted by Ludedude,Aug 25 2004, 10:32 AM
The bushings are made from cast iron?
Yes, suspension pieces can bend.
Administrator
I'd say it's possible, yes. I'm not a metallurgist, nor do I play one on TV, but I think a lot depends on how/where the stress is applied and how fast the forces build on the part. Also, a great deal depends on the metal used; I'm pretty sure that it's not pure Fe that our suspension bits are made of or they'd rust to pieces in short order.
Yes, they can bend. It is usually unlikely because the weld of the bracket that they are bolted to would most probably fail, or the bushing will take the brunt of the energy. But if you do bottom out your suspension repeatedly, and use very high spring rates, such events will create some deflection over time.
I hopped a curb once (with my former Subaru) and the cast iron exhaust header bent pretty good. No-one noticed it and no exhaust hangars, bolts etc, bent or broke off. It was only until I was installing a turbo kit and the darned thing did not fit that I discovered it. Thankfully my buddy offered me the use of his.
Cast iron is quite ductile, unless it is cast poorly with many defects. Carbon steels can be quite a bit more brittle however.
Bassem
Bassem
Bassem
Originally Posted by Joe in STL,Aug 26 2004, 07:52 AM
I hit a curb and the lower control arm BROKE IN HALF! So they may bend a little, but after a certain point they snap.
