s2000 Rear toe arm (bumpsteer kit) problem
So i've been having this problem with my rear right clunking when turning slowly I jacked my rear up the right rear has play side to side and the clunking from the side to side is coming from the toe arm (bumpsteer arm) my mechanic said it was broken internally has anyone had problems with these? They are cheap ebay ones but will i have to buy new ones or is there a way to fix?
they cannot break internally...there is a tie rod on each end (1 is reverse thread) and they are replaceable. somewhere in my build thread are mcmaster-carr part numbers for the ones on the t1r kit, which i would bet are the same as yours.
