s2000 not starting
Old 12-28-2007, 07:48 AM
algeusis's Avatar
Default s2000 not starting
hi
my s2000 just survived an exident. all body work is finished, srs replaced. but engine does not start. engine check CEL is not working, can't hear fuel pump working when turn the ignition. is there any fuel blocking system??
please help couse i'm not good in electrics
Old 12-28-2007, 08:09 AM
Iceman1's Avatar
Originally Posted by algeusis,Dec 28 2007, 11:48 AM
hi
purely speculation, but there's probably a detonation system for the battery positive cable that was probably detonated due to the impact to stop the fuel pump... the cable system may need to be replaced... you may also need a new battery... have your bodyshop call your dealer...
i know there is in BMW's... ( i know... i know... different car)
Old 12-28-2007, 08:44 AM
negcamber's Avatar
Well...not sure what a detonation system is...but I agree that if the car has been sitting for a while undergoing repairs, the first place I'd look is the battery.
Old 12-28-2007, 12:48 PM
algeusis's Avatar
the batery is new, the thing is, starter works, but it does not start, and when i turn the ignition, all the lights come on then off, but chech engine light does not, i am not able to find out the codes couse do not have obd2. tried ECM reset, removed back up fuse, but nothing. maybe ecm is damaged?don't know what to do,heeeelp
Old 12-28-2007, 03:24 PM
SUPERAnimal's Avatar
I am not 100% sure but i believe the s2000 has an inertia switch that ,during an impact, opens the fuel pump circuit. The switch can easily be turned back on. Not 100% sure but i can try to find out later tonight.
Old 12-29-2007, 02:28 AM
algeusis's Avatar
i was thinking about this swich, but there is nothing in manuals.
Old 12-29-2007, 12:02 PM
krikke_s2000's Avatar
i have a drawing out of my manual
but how kan i post this
Old 12-29-2007, 12:45 PM
algeusis's Avatar
which page is it? mybe i have it too
Old 12-29-2007, 01:33 PM
it is on page 152 but its a dutch manual
Old 12-29-2007, 03:49 PM
algeusis's Avatar
not the one i've got. if i give you my email, would that work? algeusis@yahoo.com
Quick Reply: s2000 not starting
