s2000 not starting
s2000 not starting
took the car off the road last week due to a damaged radiator and broken fan switch, replaced with new parts tonight and just had the car idling away for 15 mins to make sure it was all bled properly, as i went to turn the car off, i noticed the EPS (electric power steering) light had came on, and the power steering wasnt functioning.
so i turned the car off, left it sitting, tried again, still no joy, so i disconnected the battery, tried again, still on...so i searched online and it turned out to be a common fault which said bridge pin 4 and 9 on the obdii port and turn 45 deg to reset etc....
when this never solved the issue i went to turn the car on and it would turn over but wont start, ive checked all fuses, the inertia switch under the dash had triggered, pushed that back in and still no joy..
on further inspection i noticed the green key light along with the engine check light wasnt coming on, even when pushing the key fob..
any ideas?
dead ecu?
any ideas?
dead ecu?
Do you have a second key that you can try? Maybe the chip in the key got messed up and won't let the car start. I've heard of probs with the immobilizer. See link.
https://www.s2ki.com/s2000/topic/564...-you-reset-it/
