S2000 idler pulley making noise?
Old 04-06-2012, 05:20 PM
Vinny_GPW-S2K's Avatar
Default S2000 idler pulley making noise?
Do you know what the part number for it I try to look up the part but can't seem to find it.
S2000 Idler Pulley?
Old 04-06-2012, 05:33 PM
dwight's Avatar
#4 31180-PCX-003?
Old 04-06-2012, 05:36 PM
This pulley is smooth surface where the belt goes around it unless I name it incorrectly I know the tensioner pulley and that not it nor its crank pulley. It sit right below the tensioner pully on the left hand side.
Old 04-06-2012, 06:47 PM
SgtB's Avatar
Autozone stocks the idler pulley for around $20. Just stash the dust shield for the stock one as it doesn't fit.
Old 04-06-2012, 07:08 PM
I just checked autozone and it has the pulley with the 6 grooves not the without grooves..Hmm
Old 04-06-2012, 07:22 PM
Idle Pulley on Cam Chain Case Could this be it?
Old 04-06-2012, 07:50 PM
SgtB's Avatar
Ah, you're right. Got my pullies mixed up! If you're feeling handy, you can just buy the bearing from grainger and have it pressed in.
Old 04-06-2012, 08:56 PM
Just the bearing cover and not the 31190-PCX-000 003 001 PULLEY, IDLE?
_brandon
04-02-2023 09:57 PM
mikefifth
08-02-2014 10:07 PM
530s2k
12-24-2005 03:36 PM
Quick Reply: S2000 idler pulley making noise?
