S2000 alarm settings
Just purchased my 2004 S2000 and the alarm seems to auto set and the doors seem to lock on there own - Both a pain!
I have had 2 x 2004's in the past and neither did this! I have the 3 button fob.
Can this mode be reset?
Sure can... if we're talking about the factory alarm, here's how to do it.
On the alarm box (under the driver's seat), there is a switch with three positions - Auto Lock, Auto, Manual.
Jim
Jim
Are you sure it's an alarm? I know that the S will auto lock if you unlock it but don't open the door within a few seconds. Happens to me when I go unlock the car but go to the trunk first. I can hear the doors relock before I get to them.
Ok, time to play the ignorant one here. I just bought my 2004 a week and a half ago. There was no owner's manual with it and I have been unsuccessful so far in finding an online copy of it. Do all the 2004's have a factory alarm on them? Or is the alarm an option that some won't have? My FOB has Lock, Unlock, Trunk, and Panic....if that helps figure it out at all.
The alarm fobs look the same as the regular one, but the "Trunk" button is labeled "Option" on the Honda alarm fob. They are not interchangeable as far as I can tell. If you have a Honda alarm, the original fob (like yours) will still lock/unlock the doors, but will not enable or disable the alarm.
OP -
The behavior you are describing is like the Honda alarm set in "Auto Lock" mode. Check your fob and see if the third button is labeled "Trunk" or "Option". If is says "Option", then it is almost sure that you have the Honda alarm, and you just need to look a little harder to find the box.
Oh - as far as I know, the Honda alarm was not installed at the factory, but was a dealer installed option only.
Anyway, have you had any luck finding the alarm box? Since your car is RHD, it might be under the passenger's seat!
Originally Posted by amphimike' timestamp='1338566103' post='21746261
Ok lets presume this is just the auto lock mode - my fob has boot/lock/unlock buttons and as I am in the UK I believe the alarm was Honda UK fitted.......
