S started running really bad today
So this Saturday I took the S to the track for the first time. The car ran great, it has a Comptech supercharger with no aftercooler and I changed the spark plugs before I went with NGK v-power plugs as recommended by xviper. I've been running these plugs the past few months and just put in a new set.
So my problem is that Sunday after driving around for a good part of the day with no problems, I decided to do a quick run up to VTEC went to reline in first to 2nd then 3rd and shut it down. When I started to drive normally I noticed a stuttering in the car. I kept driving untill I could get to a good place to pull over. It seemed to randomly stutter and jerk. When I pulled over I scanned the ECU and only had my normal P0411 air pump code. So I reset the ECU to make sure that it wasn't confused for some reason.
After re-setting the ECU the car ran worse then ever. It could hardly idle, shaking like crazy and would stall after touching the gas. I turned it off and let it sit for a little while. I would have called a tow truck at this point but I forgot my cell phone and pay phone are few and far between these days.
I let the car sit for about 15 minutes or so then decided to start it up again. It idled ok and seemed better so I started home again. Same problem started again right away. I eventually made it home.
I pulled the plugs when I got home and they looked very black.
So I put the old plugs back in hoping it might fix the problem, but no such luck. Anyone have an idea of where I should start troubleshooting? I'm just guessing but maybe the fuel pump is starting to go?
did you get new wires also? if its a spark plug wire heres a way to test: turn the engine on. then unplug the wire from the engine and unplug slightly enough so you here a ticking sparking noise. if you here its fine. but if you dont here a ticking sound. its probably the wire
I'd do a compression check first thing. If they comes back OK, you probably didn't bend anything. I'd check the fuel pressure and make sure it's at least stock (43 PSI or so with the vacuum line disconnected). If those two things are OK then it indicates an ignition problem.
I'd put a new set of plugs in and see if the problem goes away.
I wouldn't start jumping to a fuel pump problem.,
haha yea it turned out that the power steering fluid was just low, how do you always know xviper
But really, the problem is resolved, It turned out to be my MAF sensor was loose. I should have done some better searching before posting.
