Running too rich or too lean, how its effected
Old 02-15-2006, 09:52 AM
  #31
Wisconsin S2k's Avatar
the only proper way around it is to use something like an AEM EMS
Old 02-15-2006, 09:53 AM
  #32
Originally Posted by s2kBryan916,Feb 15 2006, 11:48 AM
I do apologize, I was reading over what I said and I didnt make it clear I was talking about Closed loop/ cruise or idle.
NP. You obviously had some decent knowledge to share, but it was confusing more than helping in this particular situation.
Old 02-15-2006, 09:59 AM
  #33
ScottyBallistic's Avatar
AEM will work but you will not pass emissions .
Best bet would be a Greedy E-Manage Ultimate with all harnesses . Yes its a piggy back but if you use the injector and ignition harnesses you can control everything after the ecu . Midrange power can be found in ignition timing , And it is OBD2 compliant
The Greedy can also work like a VAFC if you don't use the inj/ign harnesses but you will be in the same situation .
The third solution I am working on
Old 02-15-2006, 10:01 AM
  #34
Banned
kayvan_pour's Avatar
Originally Posted by S2kracka,Feb 15 2006, 10:52 AM
You would be resetting the ECU a lot, plus when you have to give the ECU time to relearn the car and your VAFC might lose its settings.
I dont think th4ee VAFC settings will be lost, they are always there... So I'll just reset the ecu for a while until I get an aem ems...
Im still confused on what the greddy emanage does....
Old 02-15-2006, 10:57 AM
  #35
resetting the ECU wont help, unless you reset your ECU right before you tuned the VAFC.
Old 02-15-2006, 11:15 AM
  #36
s2kBryan916's Avatar
Old 02-15-2006, 11:26 AM
  #37
Yes and No , You would have to reset the ECU every few minutes as you drive so the ECU never learns
read my last paragraph even though it is confusing I know I just re read it . But I have updated it in red below .
And resetting the ecu will not fix this problem as you will be on different set of tables than when you tuned the car on the dyno . And even if you reset the Ecu before you dynoed it was changing the shorterm and longterm trims on every pull , so your settings would keep on changing .
so you would see improvements without touching the VAFC for the first pull till around the 3rd or 4th pull .
If you notice when people are just making runs without tuning that the 2nd or 3rd run nets them the highest # without tuning anything , This is because you ECU has switch and retuned the maps for more aggressive driving . After that the #'s will stabilize and start dropping depending how many pulls you have mad due to heat soak .
Kayvan , I will be looking forward to your call .
Old 02-15-2006, 11:58 AM
  #38
Banned
Thanks again bud .
I'll try to give you a call around 4:30 west cost and if I can't get a hold of you today, I'll try tommrow for sure
Old 02-15-2006, 01:47 PM
  #39
Race Miata's Avatar
Can you elaborate on that? Is it because of (lack of) ODBII?
Old 02-15-2006, 01:50 PM
  #40
Yes the lack of that too !!
and of coarse the lack of OBDII
Quick Reply: Running too rich or too lean, how its effected
