Running light replacement
So My running light burned out or didn't get reconnected when I took it to the body shop. I plan on removing the front bumper to replace it, but I need to find out where I can get the bulb? Do I have to go to honda to buy it? Any tips for replacing it?
I did a search for it before I posted, and couldn't find anything... sorry if this is a repost.
TIA
TIA
It's just a regular sized bulb. You can get it at any Auto parts store, Wal-Mart, wherever. When you go there they should have a book or a guide that will tell you what size it is, cause I can't remember.
Originally Posted by jetboater,Feb 15 2008, 03:05 PM
you shouldn't have to remove the bumper to get at it---you should be able to reach all the headlight and parking light bulbs from under the hood---kinda tight but definitly doable
wait...if you're asking where to get a regular bulb, then you probably are not familiar with taking off the front wheel fender liner. You'll need to familiarize yourself with how the plastic body clips work or else you might end up breaking them in the process, which will lead to further frustration. You'll also need a 10mm socket.
