RSM w/ G sensor help?
for any size wheel...
just use your rolling diameter versus standard rolling diameter of the s2000...
how do you find out the rolling diameter?
*whip out the good ol measuring tape*
for super accuracy u can all up honda for the exact diameter of stock
then call up your tyre manufacturer for measurement of aftermarket tyre..
dun forget to specify the exact psi
heheh some people...
what are the rest of the things we have to input to make it work with the s2k...i just got mine installed today
my cyl is correct
sp1 i have at 2p.....says im going 25,000km/h and my rpm never goes above 1000
adj is fine set at 106% using the chart
100% tires is fine (stock)
the weight i have at 1350 it calibrated itself at that wieght
what else could i be missing?????/
my cyl is correct
I have mine working right now, and if i ever get it out of the shop i'll be happy to check the settings for you. Just keep in mind, it has to be wired right too I'll let you know next week if your still haveing any questions.
Brandon
Brandon
