RPMS go below 1K (Normal???)
Old 04-06-2004, 08:11 PM
dut
dut's Avatar
Originally posted by CoralDoc
My idle RPM is around 900 all the time. I have noticed momentary drops below that causing some shaking every now and again, but it hasn't been anything I've been concerned with.
- I just got my '02 from a dealer about 9 hours ago and I noticed the same thing on the way to work...
- I didn't get too worried though...
- my car has 7,000 miles
Old 04-06-2004, 08:40 PM
Chitah831's Avatar
Happens to me every now and then also. It happens A LOT when I first start my car when the engine is already warmed up and doesn't automatically rev higher as when it's cold. After that it's usually fine.... Anyone else have this?
Old 04-06-2004, 08:43 PM
Kekoa's Avatar
Yup. exactly. It happens to me at every damn stop light or when I come to a complete stop in traffic.
Old 04-06-2004, 08:54 PM
Xplosiv's Avatar
[QUOTE]Originally posted by Kekoa
Old 04-06-2004, 08:57 PM
Chitah831's Avatar
Amazing... our car achieves such a high rpm where other engines would choke to death... but on the opposite end of the rpm band at a mere idle our engines are on the verge of dying and chokes itself to survive. WEEEIRD! Oh the irony...
Old 04-07-2004, 05:14 AM
Tex2000's Avatar
My car is opposite. When it had under 5000 miles it would idle under 1000 rpms. Now it always idles at 1000 when warmed up. I have 14,500 miles now.
Old 04-07-2004, 05:38 AM
Squeezer's Avatar
its normal, its the ECU learning new conditions, probably caused by the weather changes (things getting warmer in the spring)
Old 04-07-2004, 06:13 AM
Dolemike's Avatar
Whoa! Almost scared me there, I thought I had engine problems at first reading this. Mine usually idles between 900-1k and ive not noticed anything abnormal.
Old 04-07-2004, 06:53 AM
hydeaway's Avatar
Mine dips down to 200-300 when drop to Neutral and settles at 900k
Old 04-07-2004, 09:57 AM
Chitah831's Avatar
Just wanted to update.
I adjusted my throttle cable to cut the slack in it about 2-3 months ago. Since then at just about EVERY startup when the engine is already warm my car would get the nasty shake and dip way under 1k rpms. But after that it would be fine. Only occassionally it would dip under and give me the shake when stopped.
I just reset my ECU and gave the map sensor about 10 wacks with a screwdriver... then I went for a drive to drop something off somewhere. I was DISAPPOINTED with the outcome. The freakin car started dipping way under 1k rpms every chance I was idling. Everytime any throttle was given in neutral whether the car was moving or not it would dip with only 1 or 2 bars on the tach, and then idle back normal. And while it did this it would give me that nasty shake. Boy I was real upset!
BUT after awhile I reached my destination, and then when I hopped back in and drove back to my apartment.. NOT 1 SINGLE low dip and no engine shakes. NONE! I think the car needs to get used to everything and the environment before it finally settles itself at the right settings. Now when I startup I don't get the shakes I previously got before doing this.
I definitely suggest everyone give this a try if you have any single problem with the engine dipping in low rpms at idle and shaking. If it acts kind of weird at first, just be patient. It SHOULD settle itself out. Goodluck
Quick Reply: RPMS go below 1K (Normal???)
